Transmission autostart and FTP logs
ZxxZ
Hi everyone,
I've been on the AC66U for a month now and I have to say it works really great for what I use it for.
I've been using Transmission on Entware and each time I restart my router (not that I do it a lot) I have to start Transmission manually through init.d. Not a big issue but I'll love to know what's happening. I've followed some solutions to no avail in trying to get it to auto start.
2ndly, as I'm using the FTP with a few family members, I would like to be able to view FTP access logs and all. How would I go achieving that? I've tried editing smb.conf but it doesn't work. I conclude that I might be doing it wrong though.
Would be glad to get any help.
Thanks!
I have no issue starting transmission from entware automatically, please post here your /jffs/services-start script
About ftp log, must be enabled in /etc/vsftpd.conf
Add modified vsftpd.conf to /jffs/configs/ and reboot
In vsftpd.conf it's possible to set xferlog_enable=YES, but where does the ftp server put this log. Is it possible to put it on my usb drive?
According to the man-page for vsftpd.conf (found by googling "vsftpd.conf"):
By default, this file will be placed at /var/log/vsftpd.log, but this location may be overridden using the configuration setting vsftpd_log_file.
transmission doesn't start automatically
Hi.
I've the same problem with transmission not starting automatically after reboot, have you solved the problem?
thanks.
Try formatting the drive using a Linux live cd like Ubuntu rather than a windows tool that formats as ext.....I had the same issue and the only thing I did to get it to work was reformatting and copying back my script and applying the correct permissions again...weird but worked.
Thanks, it worked!
