Transmission email notification not working
Goldeneyez
So I've on this for a while now and just can't get it to work. Finally throwing in the towel and asking for help. Been searching about it for a while and tried a lot to no result.
Using entware transmission and did the tutorial from this page
https://github.com/RMerl/asuswrt-merlin/wiki/Installing-Transmission-through-Entware
I'm 100% sure I've set up the basic stuff correctly.
Now the problem is that I'm getting AUTH FAILED every time the script activates. I'm using Gmail SMTP:
SMTP="smtp.gmail.com:587"
FROM="blabla@gmail.com"
TO="blabla@gmail.com"
USER="blabla@gmail.com"
PASS="correctpassword"
"Access for less secure apps" in gmail settings is on. Turned it off and on again, same result.
I just have no idea what I've been doing wrong and thought of maybe someone else using Gmail to enlight me with some knowledge or something I've maybe overlooked.
I have not. I'm kind of a newbie when it comes to this.
Would I need to do this:
wget -c -O /jffs/configs/Equifax_Secure_Certificate_Authority.pem http://www.geotrust.com/resources/root_certificates/certificates/Equifax_Secure_Certificate_Authority.pem --no-check-certificate
and I'm not entirely sure where I would need to include the code. Should it in the end look like this?
#!/bin/sh
SMTP="your-smtp-server:587"
FROM="your-email-address"
TO="your-email-address"
USER="email-user-name"
PASS="email-password"
FROMNAME="Asus Router"
torrent_name="$TR_TORRENT_NAME"
echo "Subject: Download notification!" >/tmp/tmail.txt
echo "From: \\"$FROMNAME\\"<$FROM>" >>/tmp/tmail.txt
echo "Date: `date -R`" >>/tmp/tmail.txt
echo "" >>/tmp/tmail.txt
echo Transmissionbt has finished downloading "$TR_TORRENT_NAME" on `date +\%d/\%m/\%Y` at `date +\%T` >>/tmp/tmail.txt
echo "Your friendly router." >>/tmp/tmail.txt
cat /tmp/tmail.txt | /usr/sbin/sendmail -S"$SMTP" -f"$FROM" $TO -au"$USER" -ap"$PASS"
-CAfile /jffs/configs/Equifax_Secure_Certificate_Authority.pem \
-connect smtp.gmail.com:587 -tls1 -starttls smtp" \
-f"$FROM" \
-au"$USER" -ap"$PASS" $TO
rm /tmp/tmail.txt
Thank you for taking the time to help
Run the wget once
Then in your script, replace the existing ‘cat /tmp/mail....’ line with this;
cat /tmp/mail.txt | sendmail -H"exec openssl s_client -quiet \
-f"$FROM" \
-au"$AUTH" -ap"$PASS" $TO
rm /tmp/mail.txt
So like this
#!/bin/sh
-f"$FROM" \
rm /tmp/mail.txt
I used the script from your link and replaced a few lines and it's working fine now.
When I run it manually, it gives me this error (assuming it's the same when it runs automatically):
depth=1 C = US, O = Google Trust Services, CN = Google Internet Authority G3
verify error:num=20:unable to get local issuer certificate
250 SMTPUTF8
sendmail: helper killed by signal 15
It still sends it fine, so it isn't a problem as long as it's working. Unless it's something I should worry about.
Thank you again for your help!
Yea just some certificate error you could spend your life trying to understand (I hate cert issues!). I wouldn’t worry if it works!
Glad to have been of service [emoji3]
