Hi. This topic has sort of been covered on different boards, but their fix don't fix mine, so I humbly present my problem to you guys in hope of using transmission outside of my home. Local connection to Transmission works, but not remotely through WAN.
My spec:
Asus RT-AC66U
Firmware Version:3.0.0.4.270.26 (Merlin build)
Entware
USB external drive 500GB, split in two partitions, 1 NTFS, 1 ext3
Using MYchosenDDNS.asuscomm.com:9091, it times out.
Using WAN-IP I got connection refused. So I checked port 9091 on grc.com/ and found it was closed! Used portforward in asuswrt web-gui to host 0.0.0.0 and got stealth. But portforwarding to the router is wrong anyway, right?
Here's my /jffs/scripts/firewall-start:
Yeah, I got a bit carried away, saw in the log something about port 34881 and unpnp listening on that port. Thought it couldn't hurt. Canyouseeme.org shows port 9091 as open btw.
Here's my .json:
*Tried with optware first, same story. Worked locally but not WAN.
*Used rm -f asusware and installed with "entware-setup.sh"
*Been through the .json a couple of times, exploring with different rpc-whitelists.
-I even went to findmyip.org with my iPhone to add that to the whitelist without luck.
*Tried turning off the firewall from the firewall setting inside the web-ui of asuswrt.
*Checked the "Transmission-deamon.lists" to see if the correct config file was being used
*Validated the json
*Tried with portforwarding in json both true and false, no prevail
What am I doing wrong?
Any ideas?
My spec:
Asus RT-AC66U
Entware
#!/bin/sh
iptables -I INPUT -p tcp --destination-port 51413 -j ACCEPT
iptables -I INPUT -p udp --destination-port 51413 -j ACCEPT
iptables -I INPUT -p tcp --destination-port 9091 -j ACCEPT
iptables -I INPUT -p tcp --destination-port 80 -j ACCEPT
iptables -I INPUT -p tcp --destination-port 34881 -j ACCEPT
iptables -I INPUT -p udp --destination-port 34881 -j ACCEPT
Here's my .json:
"alt-speed-down": 500,
"alt-speed-enabled": false,
"alt-speed-time-begin": 600,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1320,
"alt-speed-up": 500,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": false,
"blocklist-url": "http://list.iblocklist.com/?list=bt_level1",
"cache-size-mb": 8,
"dht-enabled": true,
"download-dir": "/mnt/Doonie-Serve/#Torrent/Completed",
"download-queue-enabled": true,
"download-queue-size": 5,
"encryption": 0,
"idle-seeding-limit": 10080,
"idle-seeding-limit-enabled": true,
"incomplete-dir": "/mnt/Doonie-Serve/#Torrent/Incomplete",
"incomplete-dir-enabled": false,
"lazy-bitfield-enabled": true,
"lpd-enabled": true,
"message-level": 1,
"open-file-limit": 32,
"peer-congestion-algorithm": "",
"peer-limit-global": 40,
"peer-limit-per-torrent": 8,
"peer-port": 51413,
"peer-port-random-high": 65535,
"peer-port-random-low": 49152,
"peer-port-random-on-start": false,
"peer-socket-tos": "lowcost",
"pex-enabled": true,
"port-forwarding-enabled": true,
"preallocation": 1,
"prefetch-enabled": 0,
"proxy": "",
"proxy-auth-enabled": false,
"proxy-auth-password": "",
"proxy-auth-username": "",
"proxy-enabled": false,
"proxy-port": 80,
"proxy-type": 0,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 50,
"ratio-limit-enabled": true,
"rename-partial-files": true,
"rpc-authentication-required": true,
"rpc-bind-address": "192.168.1.1",
"rpc-enabled": true,
"rpc-password": "XXXXXXXXXXXXXXXXXXXXX",
"rpc-port": 9091,
"rpc-url": "/transmission/",
"rpc-username": "dooniem",
"rpc-whitelist": "192.168.*.*,127.0.0.1",
"rpc-whitelist-enabled": true,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": false,
"script-torrent-done-filename": "",
"seed-queue-enabled": false,
"seed-queue-size": 10,
"speed-limit-down": 1000,
"speed-limit-down-enabled": true,
"speed-limit-up": 70,
"speed-limit-up-enabled": true,
"start-added-torrents": true,
"trash-original-torrent-files": true,
"umask": 0,
"upload-slots-per-torrent": 10,
"utp-enabled": false,
"watch-dir": "/mnt/Doonie-Serve/#Torrent/Watch",
"watch-dir-enabled": true
*Validated the json
Any ideas?
