Transmission for Optware
lostindark
Hi, today i've replace my router from N66 to AC87, and when i try to install transmission through optware i'm using merlin's wiki.
After thi scommand: /opt/etc/init.d/S95transmission start
I've recieve this error msg: /opt/etc/init.d/S95transmission: line 1: syntax error: unexpected newline
Can you help?
Optware (MIPS router) and Entware (ARM router) are outdated and replaced recently by Entware-NG! :eek:
Any reason you are not using the newest and supported Entware version? :rolleyes:
By the way: Entware-NG runs like a charm on both on my routers (incl. Transmission on the main one - see my footer)! :D
With kind regards
Joe :cool:
PS.: Are you aware of the limitations for Transmission to run on the router? I mean the tiny memory and low CPU power - plus connection issues as some ISPs are blocking file sharing (dependent on the no. of connections)?
The very first line of the /opt/etc/init.d/S95transmission file should be a shebang, like:
#!/bin/sh
Can you check if that's the case?
