transmission is shutting down
pokazene_maslo
Hi.
Every couple hours i find my transmission daemon turned off. So I have to start it manually every couple hours. Any idea what's causing this? Or how to fix this?
my setup: AC66u, 3.0.0.4.374.34_2, entware: transmission 2.82 and pyload
Anything logged into /tmp/syslog.log?
Could give a hint where to search for the problem... :rolleyes:
In general: RAM shortage might cause this.
I always run Transmission with swap file enabled.
With kind regards
Joe :cool:
just very long list of
Nov 18 01:42:19 dropbear[16559]: Exit before auth: Disconnect received
Nov 18 01:42:19 dropbear[16560]: Child connection from 117.79.91.204:54778
Nov 18 01:42:19 kernel: ACCEPT  <4>ACCEPT IN=eth0 OUT= MAC= <1>SRC=201.214.201.64 DST=192.168.1.1 <1>LEN=131 TOS=0x00 PREC=0x00 TTL=112 ID=4270 PROTO=UDP <1>SPT=23894 DPT=25000 LEN=111
Nov 18 01:42:20 kernel: ACCEPT  <4>ACCEPT IN=eth0 OUT= MAC= <1>SRC=94.242.229.164 DST=192.168.1.1 <1>LEN=60 TOS=0x00 PREC=0x00 TTL=53 ID=43080 DF PROTO=TCP <1>SPT=56825 DPT=25000 SEQ=3100366437 ACK=0 WINDOW=14600 RES=0x00 SYN URGP=0 OPT (020405B40402080A2E557E2D0000000001030307)
Nov 18 01:42:20 kernel: ACCEPT  <4>ACCEPT IN=eth0 OUT= MAC= <1>SRC=119.84.110.111 DST=192.168.1.1 <1>LEN=129 TOS=0x00 PREC=0x00 TTL=47 ID=0 DF PROTO=UDP <1>SPT=20406 DPT=25000 LEN=109
Nov 18 01:42:20 dropbear[16560]: Login attempt for nonexistent user from 117.79.91.204:54778
Nov 18 01:42:21 kernel: ACCEPT  <4>ACCEPT IN=eth0 OUT= MAC= <1>SRC=124.232.148.147 DST=192.168.1.1 <1>LEN=129 TOS=0x00 PREC=0x00 TTL=47 ID=0 DF PROTO=UDP <1>SPT=20206 DPT=25000 LEN=109
Nov 18 01:42:21 dropbear[16560]: Exit before auth: Disconnect received
Nov 18 01:42:21 kernel: ACCEPT  <4>ACCEPT IN=eth0 OUT= MAC= <1>SRC=61.147.76.39 DST=192.168.1.1 <1>LEN=129 TOS=0x00 PREC=0x00 TTL=47 ID=0 DF PROTO=UDP <1>SPT=20206 DPT=25000 LEN=109
Nothing that would suggest that something is wrong with transmission.
On the note of creating a swap file for transmission....is there a how to on this setup? I'm having similar problems with ac 66u from time to time and maybe swap space will help...thanks for any assistance.
