Whenever I try to add more than a torrent at the same time (or a very large file) to Transmission, installed on a R-pi3 that's wired to an Asus RT-AC66U, transmission just stops responding.
This also happened when transmission was installed on the RT-AC66U through Optware/Entware (don't remember wich one, was some time ago) using Asuswrt-Merlin firmware, so i guess the problem is not on the R-pi3 side.
When this happens and I try to restart the R-pi3 it takes a very long time because the shutdown process can't stop Transmission so i usually have to restart it by disconnecting the power cable.
The downloads are stored on a HDD plugged-in to the router wich is formatted as NTFS so i can acces it from my windows computer.
I've tried 3 different HDD with the same outcome.
Please can anyone help me resolve this problem?
Thank you in advance.
