I have an ASUS RT-AC66U loaded with Merlin's Beta 3 FW.
Experiment with OpenVPN Client, jffs, scripts and all seems to be working correctly.
I am now at the stage of replacing my Apple router with ASUS router.
My FreeNAS server which I have setup with Jail and sabnzb/sickbeard/couchpotato/transmission/...all working perfectly when connected to Apple router. When FreeNAS server connected to the Asus router transmissionbt stop functioning, it stuck at getting magnet link metadata.
A quick check on "peers port 51413", confirms that "port closed". I can see from the WAN-> Virtual servers/Port forwarding that the correct TCP port and correct IP is listed.
Do I need to turn on "port forwarding" or is this automatically done?
Firewall need to be changed in addition?
