On my RT-AC68U, I enabled the AIProtection, specifically, the Vulnerability Protection and the Infected Device Protection and Blocking.
I was recently sent several AIProtection Alert emails with the following message:
Event number : 1
Alert type : VP victim
Device : Vaio Wireless 00:27:10:47:05:xx (xx inserted by me for this post)
URL/IP access : 192.168.10.51
Event number : 2
Suggest action: Your client devices has been detected suspicious networking behavior and blocked connection with destination server to protect your sensitive information.
Based on our recommendation, you can
1. Remove app that access this site and don't visit this website to prevent any personal information leak.
2. Check your router security setting.
3. Update security patch for your client or new firmware for your router.
Please refer to attached log file for detail information. You also can link to trend micro website to download security trial software for your client device protection.
And the contents of the attached log file read:
2015-03-12 14:05:51 00:27:10:47:05:xx is attacked by 192.168.10.51 via TCP 443, this action has been blocked.
It appears I'm not the first to have had this kind of message, where it seems that my laptop attacked its own wireless adapter. But what is disappointing is:
1. It doesn't say what "VP victim" means.
2. Truly, the standard of the English in scam emails I get from Nigeria is of far better quality than the English in this message.
3. It tells me nothing about which "app" caused the problem but tells me to remove the "app" and not to re-visit the website.
4. It also tells me to "Check your router security setting." Unfortunately, it doesn't bother to tell me which setting it has in mind or what I should check it for.
Having tried unsuccessfully to send feedback to ASUS concerning its AC68U user manual, I have, instead contacted Trend Micro to state my disappointment over the poor quality of its alert.
It's only the fact that RMerlin runs some of the AIProtection modules on his own router that stops me turning AIProtection off. In the meantime, I hope to find out what caused the alert to be sent, and, if Trend get back to me, I'll re-post.
Event number : 1
Event number : 2
