Trend Micro filtering via InstantGuard on your phone?
lenovomen
I have an Asus tuf 3000 v2 router. My question is if I use InstantGuard on my phone, why does the Ai protection virus filter not work? Are the more expensive models only able to do this?
You are using a VPN on your phone which may bypass (via the encrypted VPN tunnel) certain features like Trend Micro AiProtection on the router.
And does this work with all Asus routers?
Of course. AiProtection (on the router) generally cannot examine/inspect what's inside the encrypted VPN tunnel that was started from a local network client device (PC or mobile device).
PS: There is a related older discussion:
InstantGuard is a VPN tunnel to the router. It can go through AiProtection to WAN if Asus wanted it this way.
