with merlin 380.65 it seems trendmicro is going out to asus.trendmicro.com or similar several times an hour every hour. no I have all the trendmico stuff turned off and not enabled.
is there anyway to kill it permanently? or a switch I can hit to disable it? I see since I am not using it it should not be doing it continuously.
any one know why it is doing it?
yes I know it is not of merlins doing and it is asus firmware.
thanks
thanks
