Trouble mounting usb drive
X82
I was originally on stock firmware and had a 1TB drive connected to the router. This showed up perfect. I connected a 1.3TB drive which also showed up. But the drive was full of other stuff since it was my old drive and the name of the drive was non descript. I plugged it into my laptop, formatted it, named it and plugged it back in. But now it just shows up as unmounted.
I can't find any setting or way to mount this drive.
Any solutions? Running 374.40 (Merlin build) currently. Also, I'm very new to the Linux world and it's commands.
Much appreciated.
Do you see a link as in the attachment?
Klick it and you may have to remove and replug the disk.
Did you use Windows to format the disk?
I did indeed use Windows.
Both drives connected are NTFS. Ive clicked the link and removed and re-inserted the drive to no avail. I will connect it to my laptop and run a dskchk just to be sure.
Update: dskchk found no errors. After the fifth re-format the drive now works. Maybe it was because I properly disconnected the drive through Windows, rather than just unplugging it?
The only thing is now the drive is named sdc1 for some reason. Even thought I named it when I formatted it. Is there a way of renaming it through the router?
ALWAYS use the proper way to disconnect a disk from Windows! Always!
Did you use spaces in the name or unrecognised characters?
Check the System Log.
To be fair, I did use spaces. I has it named "1.3TB Media Drive".
Here is the log:
Mar 28 13:44:03 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 6
Mar 28 13:44:03 kernel: usb 1-1.2: configuration #1 chosen from 1 choice
Mar 28 13:44:03 kernel: scsi3 : SCSI emulation for USB Mass Storage devices
Mar 28 13:44:05 kernel: scsi 3:0:0:0: Direct-Access     SAMSUNG  HD154UI               PQ: 0 ANSI: 4
Mar 28 13:44:05 kernel: sd 3:0:0:0: [sdc] 2930277168 512-byte hardware sectors (1500302 MB)
Mar 28 13:44:05 kernel: sd 3:0:0:0: [sdc] Write Protect is off
Mar 28 13:44:05 kernel: sd 3:0:0:0: [sdc] Assuming drive cache: write through
Mar 28 13:44:05 kernel:  sdc: sdc1
Mar 28 13:44:05 kernel: sd 3:0:0:0: [sdc] Attached SCSI disk
Mar 28 13:44:05 kernel: sd 3:0:0:0: Attached scsi generic sg2 type 0
Mar 28 13:44:05 hotplug[711]: USB /dev/sdc1(ntfs) failed to mount at the first try!
Mar 28 13:44:05 kernel: ufsd: use builtin utf8 instead of kernel utf8
Mar 28 13:44:17 hotplug[711]: USB ntfs fs at /dev/sdc1 mounted on /tmp/mnt/sdc1
Mar 28 13:44:17 kernel: ufsd: sdc1 without journal
Mar 28 13:44:17 rc_service: hotplug 711:notify_rc restart_nasapps
It will not use the name given if you use spaces.
Is it working now?
It is working fine now. Apart from the name.
After I'm done with it, I will connect it to laptop again and rename it to something else, hopefully this wont ruin it.
Thanks for the information!
