I am really getting mad...
54mbps in both 2.4 and 5 is the only way to have wireless working.
130mbps which is default says "internet access" but nothing can be browse, I can ping the router 192.168.1.1 though.
300 does not work either even if the card has N enabled.
Either the my wifi card AR5B93 is not a very good card and works only with G or there is something wrong with the router or settings or both.
I did not change anything, except disable the "meter stuff" after reading about the issue with it.
Any help please? or is 54G the only way to connect?
The manual says that 130mbps should allow b,g,n connections.
I need some help, link to a guide to set t up
Regards
Regards
