Troubleshooting Adblock
gatorback
Installed: the 'advance method' adblock procedure:
http://www.snbforums.com/threads/adblocking-with-combined-hosts-file.15309/
The router log indicates:
Dec 23 13:05:49 dnsmasq[8541]: read /tmp/mnt/sda1/hosts/hosts.blocked - 73807 addresses​
Router and PCs were rebooted. Router indicates:
root@ECHO:/tmp/home/root# grep 'adxpansion.com' /tmp/mnt/sda1/hosts/hosts.blocked
0.0.0.0 ads.adxpansion.com
0.0.0.0 adxpansion.com
0.0.0.0 cs.adxpansion.com
0.0.0.0 cs1.adxpansion.com
0.0.0.0 dev.media.adxpansion.com
0.0.0.0 media.adxpansion.com
0.0.0.0 www.adxpansion.com
0.0.0.0 ad2.adxpansion.com
0.0.0.0 tracker.adxpansion.com
root@ECHO:/tmp/home/root# nslookup adxpansion.com
Server: 127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
Address 1: 0.0.0.0 0.0.0.0
root@ECHO:/tmp/home/root# nslookup yahoo.com
Server: 127.0.0.1
Address 1: 2001:4998:c:a06::2:4008 ir1.fp.vip.gq1.yahoo.com
Address 2: 98.138.253.109 ir1.fp.vip.ne1.yahoo.com
Address 3: 98.139.183.24 ir2.fp.vip.bf1.yahoo.com
Address 4: 206.190.36.45 ir1.fp.vip.gq1.yahoo.com​
I believe (please correct if this is not true) that Adblock is working correctly because the adxpansion.com is resolved to 0.0.0.0
From a Windows box: pinging adxpansion.com:
C:\WINDOWS\system32>ipconfig /flushdns
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
C:\WINDOWS\system32>ping adxpansion.com
Pinging adxpansion.com [66.152.78.141] with 32 bytes of data:
Reply from 66.152.78.141: bytes=32 time=69ms TTL=46​
Why is adxpansion.com resolved to 66.152.78.141 and not 0.0.0.0?
Changed: Advanced Setings => WAN => Internet Connection => WAN DNS Setting => Connect to DNS Server automatically=YES Rebooted router and rebooted Windows box and observed the same name resolution results.
Actionable suggestions / diagnostic questions are appreciated. Thank you
