Trying to connect via a proxy with IP tables- but stuck
mrdude
Sorry if this has been discussed before - but I have been trying for hours with various options to connect to a proxy server, I have put the following in my jffs/scripts/firewall-start file:
PROXY_IP=87.246.54.12
PROXY_PORT=3128
LAN_IP=`nvram get lan_ipaddr`
LAN_NET=$LAN_IP/`nvram get lan_netmask`
/usr/sbin/iptables -t nat -A PREROUTING -i br0 -s $LAN_NET -d $LAN_NET -p tcp --dport 80 -j ACCEPT
/usr/sbin/iptables -t nat -A PREROUTING -i br0 -s ! $PROXY_IP -p tcp --dport 80 -j DNAT --to $PROXY_IP:$PROXY_PORT
/usr/sbin/iptables -t nat -I POSTROUTING -o br0 -s $LAN_NET -d $PROXY_IP -p tcp -j SNAT --to $LAN_IP
/usr/sbin/iptables -I FORWARD -i br0 -o br0 -s $LAN_NET -d $PROXY_IP -p tcp --dport $PROXY_PORT -j ACCEPT
Some other entries in that file work fine so I know that the script is executing properly.
I was expecting when I go to check my IP that it would be the same as the proxy - but it's not, what am I doing wrong? thanks.
You are wanting the router to redirect all LAN traffic through the proxy?
I think your iptables setup assumes the remote proxy is a similar iptables setup, rather than a standard socks or http proxy.
Also, are you sure you want to send all traffic unencrypted?
Yes all traffic is to go via the proxy, I don't know about the proxy servers iptables - I just want to be able to use any free proxy server, also I don't care about encryption as I just want to be able to do this now and again - I will disable it when not required.
You need a service to translate your raw network traffic into whatever protocol the proxy uses.
Rather than trying to do this at the router, I would do this at the client. There's a neat program called proxychains that can tunnel command-line programs.
Can I ask why you are trying to proxy? If you want to browse pseudo-anonymously, there are all sorts of plugins & addons for standard web browsers.
I have an oscam card server running from my router and sometimes I want to be able to connect to people via a proxy, as it's running from the router itself and uses different ports and both udp and tcp I can't use any plugins or a web browser - or any other windows software. That's why I want to use Iptables to connect to the proxy.
Can socks/http proxies even handle UDP?
