LighthammerX
Greetings,
I have a bit of a weird problem I am trying to resolve.
I'm working on building out my smart home with all the smart things and to keep it all sorted for sanity and potential troubleshooting, I've been making dang sure to assign everything to IP pools via the DHCP.
I'm running an ASUS RT-AC3100 (Merlin firmware) as my main router with an ASUS AX3100 (Default ASUS Firmware, up to date) and a ASUS AX5400 (Default ASUS Firmware, up to date) building out my AiMesh.
To manage the DHCP, I'm using the YazDHCP addon on my RT-AC3100.
With all the IPs I have assigned to smart devices, I believe I am having issues with devices trying to use the AIMesh. The RT-AC3100 is receiving most, if not all of wireless traffic.
I've tried binding some devices to AIMesh Nodes but it won't let me because I have too many things assigned to the DHCP.
I think I could clear the DHCP table, add the AIMesh Node Bindings then readd the DHCP tablefrom YazDHCP; but I am looking for a less hacky solution to run my DHCP with the sublet pools I like to keep things organized but be able to force IP Bindings.
I believe my problem comes back to I need a better DHCP solution and wanted to see if anyone has any thoughts on how I could shift the DHCP duties to another device.
I'm not really sure how to force the network to follow a DHCP with this router setup.
Thanks in advance.
Thanks in advance.
