Brandon Gabbard
I'm trying to implement VLANs on my RT-AC3100 in AP Mode. Main LAN is VLAN 1, untagged on ports 0-7, tagged on 8 (but shouldn't matter since I'm not using it as a gateway). IoT Net is VLAN 4, tagged on port 0 and 5 (but not sure thats right).
I found the following script which seems like it should do what I want but it's written for an AC68U not a 3100, so I'm don't think the internal CPU port is 5 on a 3100?
https://gist.github.com/SAPikachu/d00b8eea099f06e6e2a7
I've modified the script by changing VLAN 1111 to VLAN 4 but no luck. I've also tried tagging port 7 instead of 5 with no luck either.
Any help would be appreciated. I have a seperate AP I've been using for VLAN 4 but it sucks and would prefer to run VLAN 4 on a guest SSID on the 3100.
