occamsrazor
So I bit the bullet and ordered a QNAP TS-239 Pro II, which am going to use with 2 x 2TB WD20EADS drives. I've read there's some problems with some Green drives, although QNAP say this particular model is OK, but will try anyway.
The drives will be storing mainly movies, music, and Time Machine backups, and I need to get the full capacity from the drives. I plan to manually backup the essential files to an external eSATA drive. Therefore I'm thinking to format the unit as Raid-0 or JBOD, not RAID-1.
Should I go for Raid-0 or JBOD? Will RAID-0 provide significantly greater speed compared to JBOD? I don't see JBOD mentioned in the charts...
Will RAID-0 be significantly louder, hotter and/or use more power?
Also, should I format as EXT3 or EXT4? I read there were some problems with the current implementation of EXT4 that were going to be fixed in a new firmware update, what are the pros and cons?
Most of my machines are Macs....
Thanks for your help. Also if anyone has experience with Jumbo Frames and Link Aggregation on this unit, please see this thread in the Switches forum.
