TS-419P Questions (Newbie on NAS)
jderosa3
I just purchased the TS-419P Turbo NAS (I should have it in hand in a couple of days). I run a small home based design firm (graphic/multimedia design), my wife does interior design and I use a PS3 for media streaming... I thought this was a good purchase.
I have a couple questions about this device:
1) I have roughly 2.5TB of data I will be transferring to this device from my local machine. I have a gigabit ethernet network and although it is fast it will still take days to copy this data to the NAS.
I see that there are eSATA ports on this. Can I hook up the external drives from my local machine to this so that I can transfer this data quickly to the NAS. Then disconnect them.
I am hoping there is a way to quickly get this data to the NAS without having to wait forever to transfer the files.
2) I am loading this NAS with 4 Samsung F2 1.5TB drives and will set it up in RAID 5. Let's say hypothetically one of the drives go bad. I understand I can hot swap out the bad drive and then it will automatically recalculate the data back to it. In this case I bought and extra identical drive...
but what if I want to upgrade to 2TB drives... do they have to be the same brand? Can I hot swap them one at a time without downtime?
3) Can the RAM be upgraded in this device? (I am a RAM junkie... I tend to just max it out... is that wrong?)​
I apologize for the lack of insight, but I am new to these devices and I want to make sure I am getting the correct info before I begin.
This community seemed to be the best out there. So thank you all for contributing - this seems like a great place to learn.
I have similar questions
thanks for posting your questions... I am surprised that there are no responses.
Maybe the newbie questions are not considered that important...
I recommend always trying the vendor's forums first. But thanks for asking here anyway.
You can do this using the Web File Manager. But I'd try a test folder copy first over the network and direct-attached. You might find the network copy faster.
2) I am loading this NAS with 4 Samsung F2 1.5TB drives and will set it up in RAID 5. Let's say hypothetically one of the drives go bad. I understand I can hot swap out the bad drive and then it will automatically recalculate the data back to it. In this case I bought and extra identical drive...but what if I want to upgrade to 2TB drives... do they have to be the same brand? Can I hot swap them one at a time without downtime?
First, you should use only drives on the recommended list.
Replacement drives don't have to be the same make/model.
Yes, you can swap one drive at a time to expand capacity. But this takes a long time since the volume must rebuild each time. You don't get the expanded capacity until all drives are swapped.
Not without voiding your warranty. http://qnap.com/faq_detail.asp?faq_id=645
One month later on the 419P
As a newbie contemplating spending so much on a technology that I had never worked with, I think that the little details were freaking me out.
I would have to say that this unit installed easily, and after a few days of loading it with data, performs perfectly with a mixed network: OSX, XP and Vista. Streaming is a breeze, access times (both read and write) are excellent, and I can easily recommend this unit to a newbie like me intending to use it for its intended use: in home, not enterprise networking. :D
I did find a couple of bottlenecks where I thought that I had Cat 5e cable, but only had Cat 5. It made a huge difference when I built and replaced the new cables.
