Dennis Wood
We just got a 16 port switch in here specifically because it was the only layer 2 managed switch I could find for under $300 that had full support for 803.2ad...or automatic link aggregation. Trunking and link aggregation was supported on the previous switch, the DLINK 1216T, but it does not fully support this specification...only static trunking.
Enter the TS509 with dual ports and the magic claim that it supported load balancing. With a static trunk set up and 2 LAN cables used, the TS509 did not load balance on the trunk which was not a surprise. QNAP specifies the switch must support automatic link aggregation, 803.2ad. Well, there are some issues there under multiple loads (and I'm working with Qnap on this) but what a surprise in testing today. The test workstation uses an ASUS (P5W-DH) board with Marvel dual LAN PCIe connected gigabit and Vista SP1 with ICH7 based RAID 0 drives. The Marvel driver supports 3 modes, basic, static, dynamic which are used depending on the switch capabilities. Dynamic is what you want, and can only be used with switches fully supporting 803.2ad....like the 3COm 2916. This switch has an amazing feature set for under $300.
My previous tests with link aggregation on the DLINK 1216T switch (using the aforementioned workstation) showed that link aggregation worked, but only in "static" mode on the Marvel driver with a trunk configured. Now with the 3COM switch, I can use "dynamic" mode, and the TS509 does work in load balancing mode.
Performance from the same workstation to the TS509 (neither teamed) was previously 45MB/s write, and about 60MB/s read. With the same workstation now configured with two gigabit LAN connections, the TS509 connected in the same manner, and the LACL trunks set up, I got a surprise. Write speeds jumped to 50MB/s and read speads are much higher at 83 MB/s using our 5.3GB test set of files. This is with the TS509 using RAID 5.
In our large file copy (200GB) tests from the NAS to the desktop, Vista is now jugging along at sustained 97.5 MB/s read. Link aggregation is not supposed to increase speed of one "pipe", but clearly something else is going on here. Any LACL experts out there? It would seem that "dynamic" LACL is capable of doubling the pipe, and increasing a single workstation's (IP address) performance.
Note that with the latest firmware 2.0.2, performance with 2 workstations loading the unit simultaneously is completely unacceptable at less then 3MB/s ... so some more code updates will be required.
