Turning off AiProtection - Malicious Sites Blocking
colinxa
Hi there,
Just noticed the Malicious Sites Blocking is still running even I turned off AiProtection, also tried with AiProtection enabled with Malicious Sites Blocking disabled. The only way I make it work is to add the site to the white list.
How to disable the AiProtection in real?
Thanks and happy New Year!
Withdraw data sharing agreement in Administration, Privacy and reboot the router. If you want only some of the TrendMicro components - re-enable and accept the agreement, but don't touch AiProtection. Turning it on/off may need the procedure done again. Make sure the sites are not blocked by Parental Controls, if you have it enabled with categories selected per device.
