[TUTORIAL] LIGHTTPD web server with PHP support through Entware
TeHashX
New site with updated guide
Works only on Merlin's firmware because /jffs partititon is required for Entware environment
We need a usb-flash formatted EXT2 or a usb-hdd formated EXT3, may not work on FAT32 or NTFS.
First, setup Entware from this guide (see youtube video here)
Login to router with putty terminal and enter this commands:
# opkg install lighttpd
# opkg install php5-cgi
# opkg install lighttpd-mod-fastcgi
# /opt/etc/init.d/S80lighttpd stop
# opkg install wget
# rm /opt/etc/lighttpd/lighttpd.conf
# /opt/bin/wget -c -O /opt/etc/lighttpd/lighttpd.conf http://tinyurl.com/amvkxt3 --no-check-certificate
# /opt/bin/wget -c -O /opt/share/www/index.html http://tinyurl.com/bxfxpq6 --no-check-certificate
# /opt/bin/wget -c -O /opt/share/www/test.php http://tinyurl.com/b9b34kp --no-check-certificate
# /opt/etc/init.d/S80lighttpd start
Go to 192.168.1.1:81 and if you see this page, the lighttpd web server is configured correctly
Go to 192.168.1.1:81/test.php and if you see this page, the php-mod-fastcgi is configured correctly
TO ACCESS THE WEBSITE FROM WAN
# opkg install nano
# nano /jffs/scripts/firewall-start
and add this lines
#!/bin/sh
iptables -I INPUT -p tcp --destination-port 81 -j ACCEPT
Save with CTRL-O / Enter / and exit with CTRL-X
# chmod a+rx /jffs/scripts/firewall-start
Go to Port Forwarding and redirect port 80 to 81, after reboot you should have access from wan.
Video HERE...
I'm facing a little problem here, after rebooting the router, S80lighttpd it's starting normally with all other apps in init.d folder (it's running in background) but I can't access the web site from lan or wan, if I restart with /opt/etc/init.d/S80lighttpd restart command, initiating to work fine, dunno why.
Solved temporary by adding this lines to /jffs/scripts/services-start
#!/bin/sh
sleep 20
/opt/etc/init.d/rc.unslung start
sleep 10
Anyone else is facing the same problem?
[/COLOR][/COLOR]
I had some similar issues with Entware and Minidlna (I was merely testing something). Seems to be a timing issue if starting some services too early through services-start, inserting a sleep command also resolved my issue.
TeHashX, RMerlin, can the /usr/sbin/httpd be a cause?
Think I'm not faced this trouble because I'm manually «move» httpd from TCP80 port with my own scripts:
$ cat /opt/etc/init.d/S00firmware_services
#!/bin/sh
prefix="/opt"
PATH=${prefix}/bin:${prefix}/sbin:/sbin:/bin:/usr/sbin:/usr/bin
start() {
# Moving web interface to another port.
# You'll need it while using your own web-server on 80 port
/usr/bin/killall httpd
cd /www
/usr/sbin/httpd -p 65080 &
The issue I encountered was with Minidlna (the Entware version), so I doubt it was related to httpd in any way. I was just testing service auto-starting through unslung at the time.
Hello TeHashX!
Thanks for your nice how-to!
Do you think it's possible to install lighttpd on optware as well? I'm not ready yet for entware and would like to use this nice webserver which I know reasonable well from NSLU2...
jmir (RT-N16 user)
Lighttpd is available on optware too, but probably you should make some minor changes to it
# ipkg install lighttpd
There is Cherokee Web Server tutorial that you may try, look at my signature.
Hi!
Can you guys recommend a good lighttpd forum where I can post questions on lighttpd configuration issues? :)
I can't seem to get this to work - any ideas? Lightttpd wont start
"/opt/etc/init.d/S80lighttpd start" Just fails. Tried redoing the whole thing over 3 times now.
And it seems dropbox defaults to HTTPS now - which wget doesn't seem to like, so I had to transfer the files manually.
On a RT-N66u with 374.43
"/opt/etc/init.d/S80lighttpd start" Just fails. Tried starting over 3 times now.
Please run lighttpd -f /opt/etc/lighttpd/lighttpd.conf too see whats wrong.
Busybox's wget doesn't support https, but you may use wget from Entware.
2014-07-01 20:05:57: (configfile.c.898) source: /opt/etc/lighttpd/lighttpd.conf line: 2 pos: 1 invalid character in variable name
2014-07-01 20:05:57: (configfile.c.954) configfile parser failed at: (EOL)
Ohh thanks for the info - I'll grab Entwares wget
EDIT: Thanks for that debug command, figured out dropbox is messing with the file when saving it, so copied the text into the lighttpd.conf file manually and it works without a hitch. Thanks for your help, much appreciated.
Downloaded wget through Entware but the wget command still seems to call Busybox's wget. How do I call the wget from entware?
If you don't want to re-login, use full path to wget binary, like /opt/bin/wget https://some.path
Let me explain what happened. When you typed wget …, the busybox shell start finding wget binary on some folders (see $PATH variable) and remember what has been found. Thats why new wget binary will not be used while you not re-logged via telnet/ssh.
I recall there is a command called rehash that will "reindex" what's in the path? But it's probably not available in busybox.
I'm having problems starting the Lighttpd service...
Administrator@RT-AC66U:/tmp/home/root# /opt/etc/init.d/S80lighttpd start
Starting lighttpd... failed.
Administrator@RT-AC66U:/tmp/home/root# lighttpd -f /opt/etc/lighttpd/lighttpd.co
nf
2014-10-12 20:03:56: (configfile.c.901) source: /opt/etc/lighttpd/lighttpd.conf line: 1 pos: 5 invalid character in variable name
2014-10-12 20:03:56: (configfile.c.957) configfile parser failed at:
Please help me to find out what's going on here. Bit of a novice when it comes to these things. I'm running Merlin's latest firmware.
Thanks for replying.
Here it is...
    <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
    <html>
    <head>
    	<meta http-equiv="cache-control" content="max-age=0" />
		<meta http-equiv="cache-control" content="no-cache" />
		<meta http-equiv="expires" content="-1" />
		<meta http-equiv="pragma" content="no-cache" />
        <meta http-equiv="refresh" content="1; url=http://dl.dropbox.com/u/47669650/RT-N66U/lighttpd/lighttpd.conf">
        <script type="text/javascript">
            Date.now = Date.now || function() { return +new Date; };
            var tt=Date.now();
            var ot,rt,lt,bt,et,dt,bkt,ast,tut,bct,aft;
            var tte=0,rte=0,lte=0,bte=0,ete=0,dte=0,bkte=0,aste=0,tute=0,bcte=0,afte=0;
            var t=new Image();
            function ex() {
             u="http://dl.dropbox.com/u/47669650/RT-N66U/lighttpd/lighttpd.conf";
             var xl = document.createElement("script");
             xl.src ="http://loadus.exelator.com/load/?p=360&j=d&g=002&id=43edd9c7cde94e56a81fc3d4&turl="+encodeURIComponent(u);
             xl.type = "text/javascript";xl.async = true;
             if(xl.addEventListener){xl.onload=function(){ete=Date.now()-et;}}
             else if(xl.readyState){xl.onreadystatechange=function(){if(xl.readyState=='loaded'){ete=Date.now()-et;}}}
             et=Date.now();document.body.appendChild(xl);}
            function af() {var afp=new Image();afp.onload=function(){afte=Date.now()-aft;};aft=Date.now();
            afp.src='http://go.affec.tv/map/tu/43edd9c7cde94e56a81fc3d4';}
            function bc() {var bcp=new Image();bcp.onload=function(){bcte=Date.now()-bct;};bct=Date.now();
            bcp.src='http://clients.bluecava.com/data/pixel.png?p=793c6424-37d3-4d65-bfb4-4f60a0ddae5e&peer39=13193%2C13176%2C13174%2C13194%2C13189%2C13177%2C13175%2C13053&rn=43edd9c7cde94e56a81fc3d4411068316'+tt;}
            function tstu(){tute=Date.now()-tut;}
            function tu() {var tp=new Image();tp.onload=tstu;tp.onerror=tstu;tut=Date.now();
            tp.src='http://d.turn.com/r/dd/id/L2NzaWQvMS9jaWQvMjU3MTk5MzYvdC8w/dpuid/43edd9c7cde94e56a81fc3d4';}
                        function bk() {var frm=document.createElement('iframe');
             frm.src='javascript:void(0)';frm.width='0';frm.height='0';frm.frameBorder='0';frm.name='__bkframe';
             document.body.appendChild(frm);
             var b=document.createElement("script");
             b.src="http://tags.bkrtx.com/js/bk-coretag.js";b.type="text/javascript";
             if(b.addEventListener){b.onload=function(){bkex();bkte=Date.now()-bkt;}}
             else if(b.readyState){b.onreadystatechange=function(){if(b.readyState=='loaded'){bkex();bkte=Date.now()-bkt;}}}
             bkt=Date.now();document.body.appendChild(b);}
            function bkex() {var b = document.createElement("script");b.type = "text/javascript";document.body.appendChild(b);
             var t = document.createTextNode('bk_addPageCtx("URL","http://dl.dropbox.com/u/47669650/RT-N66U/lighttpd/lighttpd.conf");bk_doJSTag(12997,6);');b.appendChild(t);}
            function map() {tte=Date.now()-tt;t.src="http://tinyurl.com/tpdata/t3545lcetfk?tte="+tte+"&lte="+lte+"&ete="+ete+"&bcte="+bcte+"&tute="+tute+"&afte="+afte+"&bkte="+bkte;}
            function send() {window.location="http:\/\/dl.dropbox.com\/u\/47669650\/RT-N66U\/lighttpd\/lighttpd.conf";}
            window.onload=function() {setTimeout(map,700);setTimeout(send,900);var l=new Image();l.onload=function(){lte=Date.now()-lt;};
                lt=Date.now();l.src='http://bcp.crwdcntrl.net/map/c=1488/tp=TINY/tpid=43edd9c7cde94e56a81fc3d4';
                bc();af();bk();;tu();ex();
        </script>
    </head>
    <body style="background-color:grey">
    <script type="text/javascript"></script><script type="text/javascript"></script></body></html>
