Two NAT OPEN Xbox ones on the Same Network problem.
warheadjc
Hi folks!it's my first post here!
I got a problem here,pretty much out of the options here.
Router:RT-AC88U
Firmware:Merlin_RT-AC88U_380.57
Problem:
When one Xbox connected everything is fine,but when the second one connected I encounter problems like sever lag and matchmaking problem with most of my online games like COD.
I got NAT open on both console and one console is Nat open for the COD game, another is moderate.
I got DHCP manually assigned IP for both of them.
I have UPnP enabled ,QoS and Firewall disabled.
Please help, I don't have the issue with my old Netgear Wndr4300 Openwrt router.
dont open NAT for either consoles. UPNP usually works better instead of port forwarding.
The UPNP implementation varies between different routers.
Have you tried allowing DHCP and Upnp to auto assign everything instead of settings the ips manually?
Also on the consoles themselves make sure upnp is on and everything on auto.
Then cold reboot modem, router and consoles after 10 min
Another idea if that doesn't work is try one of them in the dmz
No I haven't try auto.doing it now.
Doing some test will report back here tomorrow!
Amazing forum guys,thanks for the help I believe my friends have this issue as well.
Hope we can help those.
