pete y testing
hi guys
just doing some testing with the above two routers and im running the 88u as the main router and the 5300 as a wireless access point
see my floor plan below
https://onedrive.live.com/?cid=7D5C...1a0742!812&parId=7d5cb240be1a0742!144&o=OneUp
88u is in location A
5300 in location D
to avoid overlap i have been using the Tx power adjustment on both units but it doesnt seem to make a great difference
with only about 10db difference between 100% and 10% , im not sure if this is right or not as i expected a much greater decrease in signal when turned down to 10%
at the mid point being location C im getting about -45 rssi for both routers when set to 10%
when tested in the same room as each router the signal is about -30 for 2.4 gig and -36 for 5 gig
i have also set the roaming assistant to -70db which is the lowest it will go , wonder why it cant be set lower
so any idea on why the transmit power percentage doesnt equate to power output
pete
5300 in location D
pete
