iAirJordan
Quick question. I searched the web a lot and would like some feedback on the tx power adjustment value. I have it at stock right now cuz idk wat to set it to..
Try getting a laptop and testing results in different places at different TX settings (jump around in 5-10mw increments).
Both OSX& Windows
offer you built in ways to check TX/RX rate, and if you have OSX I put some more tips on the built in wireless utility here. I'm sure similar stuff exists for Win for free or built in.![]()
Besides getting best RSSI and tx/rx speeds, actually push files across (1gb+) to test and make sure that it holds up.
I personally use around 150mw for 2.4ghz and 110mw for 5ghz, but also neighboring traffic (or lack thereof) helps figure out what is best. But as prev response said if you don't know, don't fool around with it, the difference between worse wifi performance and better formance might only be a few mW, you really have to test and make sure and also keep an eye on your router temps http://192.168.1.1/Advanced_PerformanceTuning_Content.asp.
Make notes of temps, RSSI on both bands, and speeds on both bands at X, Y, & Z positions in your home/apartment/building (like I said also try to do a large file txfr text, pushing something over your lan via wifi at that location). Then adjust power on one band, and measure all those things again, etc. That's really the best way to dial it in and goes quicker than it sounds.
hth
This makes me curious...are you having range problems? Is there a signal strength problem? Have you played with the settings yet? I found that the best improvements I could make were to orient the antennas so that the strongest signal went to the furthest area. You may be surprised how much difference playing with the antenna (and router) orientation can make. I'd personally just leave it at the default power. If you double the power, you get at most 3dB, risk distortion of the signals, and raise the heat level of your router. Raising the temperature can shorten its life.
As a general rule i wouldn't tinker too much with your output power, this will cause the router to run warmer, and most likely wont give you any significant performance gains. IMHO
@RogerSC, I'd be curious to hear your input on this. . .say on the RT-N66U which has the 3 small omni-directional antennas, and it uses some magical beam forming or something, is it possible to literally aim them at something? (other than orienting the antennae 90 degrees down so they were parallel with the router giving it a completely different polarization?)?
Luckily, the with the newer routers, at least in my RF environment and physical space, the need for me to play around with aiming has decreased substantially.
I'd be interested in hearing what cause & effect you've observed with the antenna, or even in some routers that don't have external antenna, re-orienting of the routers themselves.
thx for thoughts in advance!
I just had a few QSO with EA, HA, stations. Still swinging the bug. Out at cabin I have
5W QRP brick radio with mile long wire antenna, LOL! Here in Canada DOC gave us
all life time licence some years ago.. No more renewal fees/paper workl. FD was last week end. Once a HAM always a HAM?
| Thread starter | Title | Forum | Replies | Date |
| T | Tx power adjustment (Asus RT-BE86U) | Asuswrt-Merlin | 4 |
We use essential cookies to make this site work, and optional cookies to enhance your experience.
