I agree there's definitely a difference. I've read some articles that say it's better to invest in business network hardware (better than all-in-one). I'm talking small business, not IBM.
Thank you both. I'll probably stick to all-in-one. As Tech9 says it's probably best for the average homeowner. Maybe one day I'll delve deeper into networking.
I would say the several APs are the big one. You have to live with slow wireless with the all-in-one router. My thinking is you want an AP in all big used rooms if you want top wireless speeds. This may be more so as we move more into the higher frequencies in the 6 GHz range.
I would want APs in heavily used rooms as the overall wireless is better. Connection rates are much lower through walls, at least my walls.
You need to adjust the power levels for multiple APs in one home. You will end up with higher connection rates when using multiple APs. And higher throughput when using different channels on those APs because all APs can transmit at the same time on different channels.
I also run these APs through a Cisco L3 switch so they switch fast. When you get a broadcast that slows a network the other networks keeps talking through a L3 switch. It is not like when a L2 switch receives a broadcast and all internet traffic stops. The more devices you have the more this stands out. Windows PCs do a lot of intercommunication on a network besides broadcasts.
Only in your mind due to your lack of understanding.You are totally lost.
An L3 switch gives you higher throughput and you are nuts if you don't run one in a large network. Small network you can get by, but it is always better to run good infostructure that can scale. If you run VOIP phones in your network, you need to be running a L3 switch to control priority to voice traffic.
Putting an AP in every room of a residential house is going to cause more problems than it fixes.
Depending on conditions. If done properly and when needed it works very well. There is no universal advice.
needing an AP in every room is a fringe situation
My connection rates are much higher with more APs. Your problems may be your problem.
I think using QoS on the vlan in a L3 switch is a better idea than using QoS with layer 2. Layer 2 CoS class of service. Very limited. Layer 3 is much better.
I would think it you had say a 600 PCs and 15 or 20 switches using all L2 switches would suck for voice traffic. You would have bottlenecks in different switches at different times. There is not enough control for the traffic.
Any way this is what I have seen in the past.
And yes, I agree the Cisco small business L3 switches are not like the big boy Cisco L3 switches that cost hundreds of thousands of dollars. The small Cisco L3 switches that I run are fast enough to segment voice traffic and prioritize it, so they are good for smaller networks in my way of thinking. There is a little overhead for L3 vs L2 because L2 is at lower level in OSI model. Once you start loading down networks, L3 is the way to go from what I have seen.
Here is the Cisco way.
I agree for North America with typical wooden houses around, but not for Europe for example. As I mentioned above I'm also using 4x APs in a brick and reinforced concrete bungalow style house under 2000sqft. All on the same control channel 36 @80MHz wide, controller managed, 20mW power (1/10 of allowed). It works very well with high throughput and adequate roaming. Wall attenuation is about -30dBm. No fringe situation there.
Welcome To SNBForums
