Unable to access Router from local IP
armsAC3100
I have an AC3100 running version 384.12. This morning I attempted to login in to router. The AC3100 login page displayed correctly and I entered my user / password. It went to 192.168.x.x and displayed a blank screen. After waiting a minute it was still blank. Everything on the router network was working fine, just not the GUI. I was able to access using SSH and router responded normally. I did do an HTTP restart, but no change.
I did a Power cycle of the router and all is back to normal. Nothing abnormal in the system log. The last entry was a normal daily "In-a-dyn version 2.5 -- Dynamic DNS update client." entry from yesterday.
As a side question is there an SSH command that I can force a full reboot?
This is the only problem I have seen since installing 384.12 several weeks ago.
Thanks, Al
Could be that the built in web server crashed. Use this in the terminal to restart:
service restart_httpd
