Unable to Activate 5 Ghz network
Gian
Hi guys,
I cannot enable the 5 Ghz network when the router (RT-AC87U- FW 380.58_0) is setup in Access-Point mode as I'm not able to get the webpage where to enable it.
I'm attaching a screenshot to show you the problem.
As you will see, the page is incomplete, I cannot scroll up or down.
Do you have an idea how to solve the issue?
Thanks,
Gian
Check that your SSIDs do not contain any special characters.....Only alphanumerics is safest.
If you are just trying to set up as an AP, worked as a router?
