Unable to build: notify_rc.o: No such file or directory
mrdude
From a clean install of the GIT, I am unable to build firmware for RT87U, I keep getting the error:
arm-brcm-linux-uclibcgnueabi-ld: cannot find prebuild/notify_rc.o: No such file or directory
Even If I manually put that file in the correct folder, whenever the make command is run to make for the router - that file gets deleted and the build fails due to it being missing, any ideas how I can stop this from happening? I had a look in the make file but couldn't see what was making it get deleted.
Cheers.
That's because gitignore filtered out those files when I merged the GPL binary blobs. I've now force-pushed them to Git.
It's fixed now with the latest commit from @RMerlin. My RT-AC87U is working fine.
As usual, keep in mind that this is very early work-in-progress code. There ARE things that aren't working at this time (most notably Adaptive QoS stops working if QoS gets restarted, but a number of other issues exist as well).
