Been using RT-AX86U for a while with updated firmware 386.7.0. Finally thought of using backup router RT-AC68U (AC1900) that was replaced by AX86U to use it as AIMesh node to get better streaming on different floor. All went well by placing AC68U in AIMesh node,connecting to AX86U via Ethernet cable. Static IP assigned as 10.2.2.250 to AiMesh that is picked up. Seemed to work quite well all evening with streaming from local devices having no issues that happened at times in the past due to WiFi deterioration or other.
Fast forward few hours:
While family member was watching movie, streaming stopped so I tried to check with this results
- Both routers are up and connected
- Connecting via browser, cannot reach either router
- when trying to connect to parent AX86U at 10.2.2.1, I get attached error
- trying to connect to AIMesh using browser gets nothing
- cannot SSH to AIMesh router and nothing that is connected to AiMesh node, either wired or wifi works
- can connect via SSH to AX86U at 10.2.2.1 however no idea what to check or do to make it see 10.2.2.250 (AIMesh)
Have rebooted AIMesh a few times to no avail. Afraid to reboot main router as my internet still works with no ability to connect to parent GUI anymore.
Any suggestions on how I can fix this?
Appreciate your help on this matter.
