Hello all,
This is my first post on SNB.
A month ago I bought an RT-AX58U (I discovered it has V2 labeled on the back ,after reading other threads for my problem).
As the title states: I am not able to flash my firmware to Merlin.
I searched for answers in other similar threads, but this was always a dead end.
What I did:
Laptop connected to the 58U wired to port 2. (several wireless devices connected, no wired devices) I don't use the USB port at all.
I was on original Asus firmware: 3.0.0.4.386_45518-g904e564 according to firmware page
Unpacked and selected Merlin firmware: RT-AX58U_386.4_0_cferom_puresqubi.w
It goes in to updating mode for several minutes. After a while I revert back to the screen to login again.
Firmware version still reads 3.0.0.4.386_45518
I execute a reboot and after that an factory reset with the checkbox marked to clear settings.
Setup the router with the same SSID name and router login details.
Reboot
I tried other Merlin version with the same result. (Merlin RT-AX58U_386.3_2)
Then I downloaded the latest firmware version from Asus site: 3.0.0.4.386.47029
I redo the same procedure as above with other firmware's, to check if I did something wrong.
After updating, I login and it states the new firmware version: 3.0.0.4.386.47029, so flashing was successful.
I execute a reboot, factory reset, setup the router again and a reboot.
Now I try Merlin RT-AX58U_386.4_0 again.
But after pressing update I get the popup "Applying settings". This goes away and I get a new popup: Invalid Firmware Upload
This also happens with Merlin RT-AX58U_386.3_2 and Merlin RT-AX58U_386.4_beta3 and Asus 3.0.0.4.386.45898 (Only this older version is available on the Asus webpage)
I reboot by unplugging power supply cable.
So what did I wrong in the first place and how to fix that?
Why am I not able to revert to an older Asus firmware and how to fix this?
What I did:
Reboot
