Unable to get traffic statistics working
mickael
I upgraded my two ASUS AC68U firmwares to the merlin version 380.65 in order to get traffic statistics.
I followed the guide https://github.com/RMerl/asuswrt-merlin/wiki/Enhanced-Traffic-monitoring but I still don't have any statistics on the traffic history.
I enabled the SSH server, and check that:
  1. my usb key is well formatted ext2 and mounted in /mnt/sda1
  2. I created a custom directory inside the mount point called traffic
  3. I configured the general > tools > other settings, with the following informations:
    1. Traffic history location: /tmp/mnt/sda1/traffic/
    2. Save frequency: 1 hour
    3. Create or reset data files: enabled (but chown now as disabled after saving)
    4. Starting day of monthly cycle: 1
    5. Enable IPTraffic (per IP monitoring): yes
    6. Create or reset IPTraffic data file: enabled (but chown now as disabled after saving)
    7. Monitor all IPs by default: yes
  4. In the /tmp/mnt/sda1/traffic/, I can see a tomato_cstats_ac9e177bea00.gz file.
  5. I enabled the ON button in General > Traffic analyzer > Statistics
Note that I can see the real time traffic in General > Traffic analyzer > Traffic monitor.
Any advice ?
Thanks,
Look at the System Log for any error message related to the database.
Also make sure you are in router mode - traffic monitoring is not possible in AP or Repeater mode.
This is unrelated to IPTraffic. IPTraffic can be seen on the Traffic Analyzer -> Traffic Monitor page. Select one of the "Per Device" entries in the pulldown menu on the right.
