Morac
I figured rather than pollute the 386.1 thread I’d create a new one and see if anyone had any ideas.
I had been running Merlin 384.19 on my RT-AC88U and upgraded to 386.1. I got a couple of lockups so I decided to do a factory reset, clear NVRAM and JFFS and set things up from scratch.
Things were well until I tried to upgrade to 386.1_2, which failed because the router said the firmware was invalid, so it failed whatever check ASUS on a firmware upgrade. It did the same thing when I tried to upgrade to the 386.2 alpha. It succeeded when I re-flashed to 386.1, which was already installed.
I tried all the following with the same result:
At this point I decided to use the Rescue Tool and flash 9.0.0.4.386.41994 which worked. I then tried flashing 386.1_2 which failed, but so did trying to flash 386.1_0, which had previously worked. I also tried factory resetting and that still failed.
On a whim, I flashed 384.19 which worked! I was then able to flash 386.1_2 successfully.
As such it seems like the only way to flash a new version of 386.x on my RT-AC88U is to downgrade to 384.19 first, but I have no idea why that would be.
I don‘t use QOS or any of the Trend stuff. I also don’t use any advanced features of the router or have any custom scripts or anything else installed.
I normally have at least 378 MB memory free.
Any idea what’s wrong?
- Removing USB thumb drive and rebooting.
- Factory reset through the UI, clearing NVRAM and JFFS and skipping setup and going to upgrade page.
