Unbound Unbound Config File(s)
Zim
I couldn't find the answer to this with my searches, so posting the question here.
As I understand it, for configuring Unbound, the config file lives here:
/opt/var/lib/unbound/unbound.config
But I find similar config files at other locations:
/opt/etc/unbound/unbound.config
/opt/share/unbound/configs/user.config
1.) What's the difference in the files? They all appear to have similar settings?
2.) To configure settings like "num-threads", "msg-cache-size", "rrset-cache-size" should these be changed in all the locations or only in /opt/var/lib/unbound/unbound.config?
3.) In /opt/var/lib/unbound/unbound.config, setting like "outgoing-range" and "num-queries-per-thread" don't exist. Can these just be added to this file under the # tiny memory cache section? I do see these settings under /opt/etc/unbound/unbound.config, hence the confusion as to which files should be modified. Do these also need to be updated in all locations?
Thanks.
This is the only file that matters. The one in /opt/etc/unbound should be a link to the lib file. The user.conf is a backup copy of your main conf. These are made by the unbound-manager script, not unbound itself.
Thanks @dave14305
So, /opt/var/lib/unbound/unbound.config and /opt/share/unbound/configs/user.config should be identical at installation? If changes are made to /opt/var/lib/unbound/unbound.config it should/will not propagate to /opt/share/unbound/configs/user.config?
Comparing /opt/var/lib/unbound/unbound.config and /opt/etc/unbound/unbound.config - they appear totally different. Any changes made to the first appears to have no impact on the latter (don't seem linked). I'm noticing that "outgoing-range" and "num-queries-per-thread" don't exist in first file but exist in the latter.
So the question is, which file do these settings need to be modified in? Should I add the entries in the first file or ONLY modify in the second file?
Only modify the /opt/var/lib/unbound/unbound.conf. It's the only one of the files mentioned that's actually read by Unbound.
I don't use unbound_manager, so I can't explain the reasoning behind it making extra copies of the config. But you can find the references to the extra files in the unbound_manager.sh script.
Thanks @dave14305
I concur with @dave14305.
S61Unbound launch file points to "/opt/var/lib/unbound/unbound.config" being the config unbound manager reads from --- check it out for yourself.
#!/bin/sh
VER="1.01"
# v1.01 08-May-2020 Martineau Allow dnsmasq bypass; (Stop dnsmasq to release '127.0.0.1@53')
if [ "$1" = "start" ] || [ "$1" = "restart" ]; then
        # Wait for NTP before starting
        ntptimer=0
        while [ "$(nvram get ntp_ready)" = "0" ] && [ "$ntptimer" -lt "300" ]; do
                ntptimer=$((ntptimer+1))
                [ "$ntptimer" -eq "1" ] && logger -st "S61unbound" "Waiting for NTP to sync before starting Unbound..."
                sleep 1
        done
        if [ "$ntptimer" -ge "300" ]; then
                logger -st "S61unbound" "NTP failed to sync after 5 minutes - please check immediately!"
                exit 1
        fi
        TXT=
        # Default unbound+dnsmasq uses 'port: 53535'; if not then assume dnsmasq bypass ('port 53')
        [ -z "$(grep "^port: 53535" /opt/var/lib/unbound/unbound.conf)" ] && { service stop_dnsmasq; TXT="(bypass dnsmasq)"; } # (Release '127.0.0.1@53')
        logger -t S61unbound "$1 Unbound DNS server $TXT $0"
fi
# set environment PATH to system binaries
export PATH=/sbin:/bin:/usr/sbin:/usr/bin:$PATH
export TZ=$(cat /etc/TZ)
ENABLED=yes
PROCS=unbound
ARGS="-c /opt/var/lib/unbound/unbound.conf"
PREARGS="nohup"
PRECMD=""
POSTCMD="service restart_dnsmasq"
DESC=$PROCS
PATH=/opt/sbin:/opt/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
. /opt/etc/init.d/rc.func
I believe unbound manager does not create a symbolic link between the two. Instead it just uses the one it places in "/opt/var/lib/unbound/" directory.
