D
Deleted member 62525
Guest
I remember that unbound-control reload command used to work on previous versions. Can someone confirm that it is still working? When I try manually run unbound-control -c /opt/var/lib/unbound/unbound.conf reload it is reporting "ok" but
it is crushing with "error: can't bind socket: Address already in use for 127.0.0.1 port 953".
Checking netstat and there is nothing running on port 953 but Unbound, however in the unbound log I see this message when unbound is trying to reload:
fatal error: Could not read config file: /unbound/unbound.conf. Maybe try unbound -dd
It seems that even if I supply -c flag to unbound-control, unbound is trying to load wrong file.
FYI, unbound-control start|stop even if I done without specify -c works just fine.
