Thank you for your comments. I know this should probably be posted on codium forums but it seems more like Merlin addon issue. I did your suggestions and added awsglobalaccelerator.com to Skynet/Diversion whitlelist. I also added your suggetions to unbound.conf file and still get the following. If you have any idea it would be appreciated. On the one hand I'm glad Skynet is working, on the other it's a pia to use some programs because of blocking issues.
E0830 13:45:29.614270 23028 api_server_client.go:131] Ping error: unavailable: dial tcp 0.0.0.0:50001: connectex: No connection could be made because the target machine actively refused it.
I'm just trying to run language_server_windows_x64.exe manually because when Sublime Text runs, a command windows opens with the same issue. Thought I'd try to manually install.
Here's the full log:
I0830 13:51:04.394805 21892 main.go:544] Starting language server manager with pid 21892
I0830 13:51:04.399304 21892 main.go:289] Language server manager attempting to connect to language server at 127.0.0.1:42100
I0830 13:51:04.425305 20036 main.go:538] Starting language server process with pid 20036
I0830 13:51:04.425305 20036 server.go:151] Language server will attempt to listen on host 127.0.0.1
I0830 13:51:04.425805 20036 server.go:158] Language server listening on fixed port at 42100
I0830 13:51:04.425805 20036 proxy.go:113] proxyplease.proxy> No proxy provided. Attempting to infer from system.
2024/08/30 13:51:04 [proxy.Provider.readWinHttpProxy] No proxy discovered via AutoDetect: winapi error #12180
I0830 13:51:04.429304 20036 proxy.go:113] proxyplease.proxy> No proxy could be determined. Assuming a direct connection.
I0830 13:51:04.429304 20036 client.go:589] [DEBUG] GET
http://0.0.0.0:50001/exa.api_server_pb.ApiServerService/GetCompletions
I0830 13:51:04.429805 20036 client.go:646] [ERR] GET
http://0.0.0.0:50001/exa.api_server_pb.ApiServerService/GetCompletions request failed: Get "
http://0.0.0.0:50001/exa.api_server_pb.ApiServerService/GetCompletions": dial tcp 0.0.0.0:50001: connectex: No connection could be made because the target machine actively refused it.
I0830 13:51:04.429805 20036 client.go:690] [DEBUG] GET
http://0.0.0.0:50001/exa.api_server_pb.ApiServerService/GetCompletions: retrying in 100ms (3 left)
I0830 13:51:04.543177 20036 client.go:646] [ERR] GET
I0830 13:51:04.543177 20036 client.go:690] [DEBUG] GET
http://0.0.0.0:50001/exa.api_server_pb.ApiServerService/GetCompletions: retrying in 100ms (2 left)
I0830 13:51:04.651795 20036 client.go:646] [ERR] GET
I0830 13:51:04.651795 20036 client.go:690] [DEBUG] GET
http://0.0.0.0:50001/exa.api_server_pb.ApiServerService/GetCompletions: retrying in 100ms (1 left)
I0830 13:51:04.760255 20036 client.go:646] [ERR] GET
W0830 13:51:04.760255 20036 proxy.go:128] proxy failed to connect: GET
http://0.0.0.0:50001/exa.api_server_pb.ApiServerService/GetCompletions giving up after 4 attempt(s): Get "
I0830 13:51:04.760255 20036 unleash.go:86] Initializing Unleash
I0830 13:51:04.955853 20036 unleash.go:106] Successfully initialized Unleash
I0830 13:51:04.975351 20036 server.go:336] Successfully created API server client
I0830 13:51:04.977851 20036 server.go:350] Successfully created API streaming client
I0830 13:51:04.996877 20036 server.go:359] Successfully initialized tokenizer
I0830 13:51:04.996877 20036 search_provider.go:169] Using database at C:\Users\Bill\.codeium\database\default/2/MODEL_EMBED_6591
I0830 13:51:05.000878 20036 search_provider.go:181] Successfully created embedding search database
I0830 13:51:05.000878 20036 search_provider.go:229] Successfully created embedding search provider
I0830 13:51:05.000878 20036 server.go:444] Successfully created exact search provider
E0830 13:51:05.001377 20036 unleash.go:57] Unleash error: Version string empty
I0830 13:51:05.003380 20036 server.go:472] Successfully created completion provider
I0830 13:51:05.042973 20036 server.go:548] Child process attempting to acquire lock file C:\Users\Bill\AppData\Local\Temp\child_lock_1725040264395305000_5578129451594774059
I0830 13:51:05.043394 20036 server.go:558] Child process acquired lock file C:\Users\Bill\AppData\Local\Temp\child_lock_1725040264395305000_5578129451594774059
E0830 13:51:05.045393 20036 api_server_client.go:131] Ping error: unavailable: dial tcp 0.0.0.0:50001: connectex: No connection could be made because the target machine actively refused it.
I0830 13:51:05.049893 21892 main.go:340] Language server manager successfully connected to new language server at 127.0.0.1:42100
