Unbound wrecked after entware update
Raphie
Just updated entware and now unbound is full of errors
Can’t uninstall can’t reinstall, any suggestions?
Bad address
[1586884010] unbound-checkconf[8006:0] fatal error: control-key-file: "(null)" does not exist
***ERROR INVALID unbound configuration - use option 'vx' to correct 'unbound.conf' or 'rl' to load a valid configuration file
1 = Update unbound files and configuration
2 = Remove unbound/unbound_manager
3 = Start unbound
4 = n/a Show unbound statistics
5 = Install Ad and Tracker blocker (Ad Block)
6 = n/a Install Graphical Statistics GUI Add-on TAB
? = About Configuration
v = View ('/opt/var/lib/unbound/'unbound.conf)
e = Exit Script
E:press desired Option key (no ENTER key reqd.) Option ==>
Bad address
3 = Start unbound
e = Exit Script
see [Release] unbound_manager (Manager/Installer utility for unbound - Recursive DNS Server)
Of course, I did. :)
A little more detail doesn't hurt though. :)
