John DeLuca
Hello I currently have unbound set up as both my ipv4 and ipv6 DNS address, i have this set up by having the ip of my router being the ipv4/6 dns addresses. An issue i keep having is if I have things set up like this and the system reboots for any reason (I have been having power outages lately) the router can not find DNS and I do not have any network connection. All of the addons will not load ether. The only way I can fix this issue is by adding a dns such as 8.8.8.8 or 1.1.1.1, letting the system grab dns again then changing back to my local ip. If I have the router to automatically pick out DNS addresses will it be smart enough to use an alternative DSN upon reboot then switch to unbound. Please let me know if you need any logs but all is up to date and I am using a gt-ax11000 router.
