Unexpected network error while accessing Samba share on 384.13 beta2
FTC
Hi, just got the subject error while running a 'robocopy' backup script against a samba shared drive on my rt-ax88u. I am not posting this in the alpha thread since not aimesh related. I reried the command and it went through succesfully.
The log reads :
Jul 21 16:56:12 kernel: ERR: rdpa_cpu_tx_port_enet_lan#213: rdpa_cpu_tx_port_enet_lan failed. rdd_rc=120 tx_rdd_error_count=4097
Jul 21 16:56:43 smbd[29716]: [2019/07/21 16:56:43.298877, 0] smbd/smb2_read.c:219(smb2_sendfile_send_data)
Jul 21 16:56:43 smbd[29716]: smb2_sendfile_send_data: sendfile failed for file completedold/xxxxxxxxxxxxxxxxxx.avi (Broken pipe). Terminating
Jul 21 16:56:43 smbd[29716]: [2019/07/21 16:56:43.302198, 0] lib/fault.c:47(fault_report)
Jul 21 16:56:43 smbd[29716]: ===============================================================
Jul 21 16:56:43 smbd[29716]: [2019/07/21 16:56:43.302283, 0] lib/fault.c:48(fault_report)
Jul 21 16:56:43 smbd[29716]: INTERNAL ERROR: Signal 11 in pid 29716 (3.6.25)
Jul 21 16:56:43 smbd[29716]: Please read the Trouble-Shooting section of the Samba3-HOWTO
Jul 21 16:56:43 smbd[29716]: [2019/07/21 16:56:43.302372, 0] lib/fault.c:50(fault_report)
Jul 21 16:56:43 smbd[29716]: From: http://www.samba.org/samba/docs/Samba3-HOWTO.pdf
Jul 21 16:56:43 smbd[29716]: [2019/07/21 16:56:43.302451, 0] lib/fault.c:51(fault_report)
Jul 21 16:56:43 smbd[29716]: [2019/07/21 16:56:43.302515, 0] lib/util.c:1117(smb_panic)
Jul 21 16:56:43 smbd[29716]: PANIC (pid 29716): internal error
Jul 21 16:56:43 smbd[29716]: [2019/07/21 16:56:43.304098, 0] lib/util.c:1221(log_stack_trace)
Jul 21 16:56:43 smbd[29716]: BACKTRACE: 0 stack frames:
Jul 21 16:56:43 smbd[29716]: [2019/07/21 16:56:43.304172, 0] lib/fault.c:345(dump_core)
Jul 21 16:56:43 smbd[29716]: Exiting on internal error (core file administratively disabled)
Jul 21 16:57:43 kernel: ERR: rdpa_cpu_tx_port_enet_lan#213: rdpa_cpu_tx_port_enet_lan failed. rdd_rc=120 tx_rdd_error_count=5121
