Unexpected open port.
TomT
Hi
I've just done a couple of online scans and they have reported port 8000 is open.
I've no port forwarding rules setup for this so I'm wondering how it is open.
Any ideas how I can track this down?
For now I've added a rule that routes 8000 to a none existent IP address.
Thanks.
Thanks.
I did enable uPnP for my sons XBOX a couple of days back, so that could be it.
Any logs etc that will show the IP that opened it ?
Quick update.
Looking at 'System Log - Port Forwarding' I can see the IP Address that has opened the port using uPnP.
Looks like one of my IP cameras has opened several ports. I've disabled uPnP on the camera and now 8000 is showing as stealth.
Not sure why the camera felt it needed these ports open, but it's not being accessed externally so having them closed shouldn't be an issue.
Now you understand why recent large scale DDoS attacks used those cameras and other similar IoT devices to generate multiple hundreds of gigabits of traffic. Those are insecure out of the box in a lot of cases.
Quite worrying that a decent brand leave the camera open to the world.
I'll make sure I check the next one when I put it up later this week.
unfortunately its part of the allure of IoT and cloud based devices , they have to open ports so you can access the devices from outside your home , eg i saw an add for a door bell system that you can answer the door from anywhere in the world , without having these ports open that wouldnt be possible
the real choice here is weather you want that convenience or not and if so thats the price you pay
That's why running OpenVPN, SSH, Samba, BitTorrent, and other services on the same box that is the gateway and firewall is also such a not good idea...
just saying...
One thing to also consider is that your ISP may have that port open as a proxy - need to understand more there before jumping - if you are not exposing any services to the outside world, and you still see that port open from an external scan...
Since disabling uPnP on the camera, all the ports are closed.
I'm not bothered about seeing a live feed from it when away from home, it emails me snapshots if anything happens and that seems enough for now.
I'll run another scan when my son has his xbox one on and see what thats opened..
It's a good thing that you're looking into it considering the recent DDOS botnet attacks...
That's why running OpenVPN, SSH, Samba, BitTorrent, and other services on the same box that is the gateway and firewall is also such a not good idea.....
What is the advantage of having these servives on dedicated servers behind the router (rather than in it); you'd still have to ensure the ports in question are unfiltered in the router's firewall and then forward those ports to your servers running SSH, OpenVPN etc? (I'm not being facetious or argumentative: I'm genuinely interested in your comments.). Back in January I wrote in a posting on this forum: "My gut instinct is that the less extraneous stuff running on the router the better, for reasons of security, stability and performance.". So I'm interested to back up gut instinct with something more scientific!
I do agree with sfx2000.
What we nowadays call a router (for home use) is no longer just a router. The WRT54 was trendsetter, even advertised such as "router + 4-port switch + wireless access point in one". A good step for home users.
These days home routers tend to be "router + 4-port switch + wireless access point + NAS + Samba + BitTorrent + network safeguard + Open VPN Server + much more in one".
In case of Asus, all routers run close to the same software, with the nearly the same features. My RT-N66U does close to the same as my RT-AC68U, the major difference is support for AiProtection (which I do not use). Of course the RT-AC68U has more CPU power, that helps the higher throughput on 802.11ac.
The reliable parts of the routers are usually the "router + 4-port switch + wireless access point". Very worth the money (as long as you make conservative choices).
How much more expertise and performance do you expect in an average USD 150 box?
The advertised extras are the commercial selling items that color the carton box and they are the trouble makers (check te forums), do not use them or at least don't expect miracles.
Main advise: disable UPnP in the router (default), keep an eye on security related firmware updates and stay in control.
I've run my router with uPnP disabled for years. But my son has always complained his xBox doesn't work correctly.
I'd opened all the ports I could find for him, but nothing helped. The xBox always shows NAT MODE Strict.
He came to me a few weeks back and asked if we could try uPnP enabled. Since then his xBox has worked much better.
NAT MODE is Open and he's not having any issues.
As fas as I'm aware the xBox is the only device with uPnP enabled.
I'll keep checking 'System Log - Port Forwarding' and see if anything new appears. I've just checked and it all looks good.
