I have googled all sorts of alternatives and havent found an answer. However i did come across small net builders and learned alot! theres some clever people on here so here goes my first ever post....
The problem
I live in the country and only get a 2megabit adsl link. But i have an unlimited mobile data Three contract on my Samsung galaxy s4 and can comfortably achieve 10x higher speeds either over a personal hotspot or over usb tethering. This works fine when i consciously want to do it (e.g. battlefiedl 4 updates!!) as i go to the trouble of positioning my pc in wifi range of the s4 which i place at the window to achieve 4 bar HSPDA+.
I have purchased Connectify which again with preparation allows me to use both adsl and mobile data simultaneously and get a bit shorter downloads.
The Question
To massively improve convenience i want to be able to walk in my house, place the s4 on a charger at the window, activate the wireless hotspot and allow all devices on on my ethernet/powerline lan to then share the mobile data connection and use selectable dual internet access rom any device on the lan.
I throught i might be able to use an old modem/router to wirelessly connect to the s4 and with an ethernet cable from router to the lan, then share but this doesnt seem to work.
I also tried connectify hotspot which got closer and would let me share the the mobile data but not over a lan connection to the laptop ....and i'd need to leave a laptop on all the time.
I also looked at purchasing mi-fi devices but none of the blurb suggests that they can do exactly what i am trying to achieve.
Anyone have a confident answer?
Mark
The problem
The Question
Mark
