Universal Plug and Play (UPnP) yet again !!!
Twiglets
For information: (Includes many ASUS Routers)
Wreckin' routers
Last month, Kaspersky warned of advanced malware, dubbed Slingshot, that uses routers to infect networks. Well, here's some more along those lines. A report [PDF]* by Akamai discusses software nasties leveraging vulnerable Universal Plug and Play (UPnP) services offered by routers and gateways to press-gang at least 65,000 boxes.
In all, Akamai estimated that around five million routers could be vulnerable to hijacking via UPnP exploits: miscreants can use the flaws to rewrite networking tables, and turn devices into proxy servers. It has compiled a list of 400 router models from 73 manufacturers that are hackable, and if you've got one of these then it's time to either upgrade your kit or mitigate the risk.
From https://www.theregister.co.uk/2018/04/14/security_roundup/
*https://www.akamai.com/us/en/multim...at-proxies-via-nat-injections-white-paper.pdf
TL;DR
Make sure you block UPnP from the 'Internet/WAN' side, if you do not need to use it.
(Should NOT need to use it 'Internet/WAN' side AFAIK ...... sure to be told otherwise real soon ;) :D)
P.S. Don't know if Asuswrt-Merlin effectively fixes this or not, apologies if it does.
Hmm, interesting that the AC86U is not on the list. Same with the newest routers. Did they just not get tested or is it fixed on those?
Well, it sure confused me, since there is an "Enable UPnP" setting on the WAN setup page of my AC68 (374.43_29E2j9527). I can see why it might be thought to be vulnerable.
Reading up on the situation, after it was highlighted it had been bought up before, it is clarified in this 'old' post.
https://www.snbforums.com/threads/consider-disabling-upnp-by-default.11440/
My Bad for missing the info that had been posted previously, although I do tend to only read things relating to Asuswrt-Merlin specifically such as Firmware updates or anything that relates to the numerous Scripts that have been developed such as AB-Solution, dnscrypt-proxy etc.
Duplicate post - locking.
(And the short answer: their methodology must be wrong, because neither Asuswrt nor Asuswrt-Merlin has ever allowed UPnP to be accessed over the WAN interface).
