I was looking at a log from a RT-N66U and I can't see anything else than dropped incoming packets. Even though I know the firewall will show up various unexplained connection attempts, this doesn't look normal because it's just about every second, all the time, 24/7 and has been like this for days.
Every connection has 39301 as destination port and there are alot of different source IPs.
Here's a short blurb from the log, masked mac & ip.
This is everything you can see in the log, it is non-stop.
After torrenting, for how long can you expect to get incoming traffic because of this? All P2P software has been shut down since 5 days and I have not been checking out the log before that.
I guess there's nothing I can do, other than ask the service provider for a new IP? Or maybe it's no big deal?
Feb 17 23:19:24 kernel: DROP <4>DROP IN=eth0 OUT= MAC=xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx <1>SRC=177.182.xx.xx DST=xx.xxx.xxx.xx <1>LEN=95 TOS=0x00 PREC=0x00 TTL=112 ID=4728 PROTO=UDP <1>SPT=34249 DPT=39301 LEN=75
Feb 17 23:19:34 kernel: DROP <4>DROP IN=eth0 OUT= MAC=xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx <1>SRC=175.136.xxx.xxx DST=xx.xxx.xxx.xx <1>LEN=131 TOS=0x00 PREC=0x00 TTL=114 ID=8527 PROTO=UDP <1>SPT=32441 DPT=39301 LEN=111
Feb 17 23:19:54 kernel: DROP <4>DROP IN=eth0 OUT= MAC=xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx <1>SRC=184.18.xx.xxx DST=xx.xxx.xxx.xx <1>LEN=52 TOS=0x00 PREC=0x00 TTL=110 ID=16776 DF PROTO=TCP <1>SPT=54331 DPT=39301 SEQ=230598312 ACK=0 WINDOW=8192 RES=0x00 SYN URGP=0 OPT (020405B40103030201010402)
Feb 17 23:19:57 kernel: DROP <4>DROP IN=eth0 OUT= MAC=xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx <1>SRC=184.18.xx.xxx DST=xx.xxx.xxx.xx <1>LEN=52 TOS=0x00 PREC=0x00 TTL=110 ID=17141 DF PROTO=TCP <1>SPT=54331 DPT=39301 SEQ=230598312 ACK=0 WINDOW=8192 RES=0x00 SYN URGP=0 OPT (020405B40103030201010402)
Feb 17 23:20:03 kernel: DROP <4>DROP IN=eth0 OUT= MAC=xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx <1>SRC=184.18.xx.xxx DST=xx.xxx.xxx.xx <1>LEN=48 TOS=0x00 PREC=0x00 TTL=110 ID=17905 DF PROTO=TCP <1>SPT=54331 DPT=39301 SEQ=230598312 ACK=0 WINDOW=8192 RES=0x00 SYN URGP=0 OPT (020405B401010402)
Feb 17 23:20:03 kernel: DROP <4>DROP IN=eth0 OUT= MAC=xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx <1>SRC=2.34.xxx.xxx DST=xx.xxx.xxx.xx <1>LEN=131 TOS=0x00 PREC=0x00 TTL=111 ID=31346 PROTO=UDP <1>SPT=12728 DPT=39301 LEN=111
Feb 17 23:20:04 kernel: DROP <4>DROP IN=eth0 OUT= MAC=xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx <1>SRC=174.97.xxx.xxx DST=xx.xxx.xxx.xx <1>LEN=131 TOS=0x00 PREC=0x00 TTL=106 ID=44324 PROTO=UDP <1>SPT=57961 DPT=39301 LEN=111
Feb 17 23:20:09 kernel: DROP <4>DROP IN=eth0 OUT= MAC=xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx <1>SRC=77.46.xxx.xx DST=xx.xxx.xxx.xx <1>LEN=52 TOS=0x00 PREC=0x00 TTL=114 ID=8732 DF PROTO=TCP <1>SPT=16627 DPT=39301 SEQ=2045335526 ACK=0 WINDOW=8192 RES=0x00 SYN URGP=0 OPT (020405780103030201010402)
Feb 17 23:20:10 kernel: DROP <4>DROP IN=eth0 OUT= MAC=xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx <1>SRC=178.126.xx.xx DST=xx.xxx.xxx.xx <1>LEN=131 TOS=0x00 PREC=0x00 TTL=115 ID=33611 PROTO=UDP <1>SPT=42926 DPT=39301 LEN=111
