unlocator on router
squirrellydw
So if I setup unlocator (Smart DNS) how can I set the router up so only my Fire TVs use it? I would like my other computers to use my regular connection? I could just set it up on the Fire TVs but like the router setup better.
ok, I'm sure this is a dumb question but where is the realm?
edit......Found it DNS filtering under parent controls
OK, think I have it setup. Just want to make sure I understand it correctly.
Under WAN - Connect to DNS Server automatically- is "YES"
Under Parental Control/DNS Filting
I have - Global Filter Mode "No Filtering" This should send everything through the default DNS correct?
I added my Custom DNS Settings to Custom 1 and 2
I added my clients to the list below and choose Custom 1 and 2 for each. For example
FireTV Family is listed twice one for custom 1 and one for custom 2.
That should send the custom DNS to the Fire TV correct?
You can't use multiple servers per device. Only the first one gets used.
