Unplugged router, moved, and no wifi lights/web management
5mall5nail5
Hey guys so kind of odd - moved my router from one room to the other. Plugged it back in, WAN connection proper, I can ping its IP if I manually set my laptop ethernet to the right IP range, but no web front end and no DHCP working. Help? Merlin 376.45
Did you try resetting the router? You'll need to reenter the config.
Whats the best way to do that?
I did the thing where I hold the WPS button and boot up the unit. It worked. Dunno what the heck happened there. I even tried to recover the firmware with the Asus utility and it kept saying unable to recover system. All is well now.
