My place isn't large, and I need to get internet to 2 places, but wifi is not reliable due to shielding.
I purchased 4 (no singles…) AV500 TP-Link TL-PA4020/10. They were promised to work across phases, and it works well to place A, but became utterly unreliable to place B, near a PC - it keeps disconnecting and needs to be unplugged & replugged. In the beginning there were only rare disconnects. I don’t' know what has changed, definitely not in room B. I tried different adapters that I own.
I have 3 phase electricity. Place A is under the same fuse as the modem, and naturally phase; place B - impossible to see what phase without dismantling the board. I also have to use splitters in all sockets.
My problem with AV/AV2 filtered adapters is that no grounded ones are made for my local sockets, so either I just use it without the ground, or I have to use some universal adapter, or make a short converter cable.
I couldn't find anything about reliability, and speed is less critical for me.
Other than trying to reroute my distribution board, can you see a different way?
How likely would buying AV2 adapters work? If so, what class? Just go for the fastest ones? Would I be able to use 2 of them with one of my AV500 in place A, without making the B connection less reliable?
Thanks in advance for any ideas!
