Related the power failure, as I have laptops, the only device with problems is the router and I don't know if it's worth to use a UPS when is more expensive than the router.
Thanks for the tip, I also wanted more info on the traffic and could not wait for the new Merlin to comeinstall YaMon
http://usage-monitoring.com/index.php
YAMon should have little or no impact upon your download speeds. Yes it is an another process running on your router but it most of the time it is idle (and you can configure how frequently checks for updates).Thanks for the tip, I also wanted more info on the traffic and could not wait for the new Merlin to come
Ater some trying it installed fine (AC87U) and was working some sort of ok I think (not all pages showed data, but that is maybe because I only had it run for an hour and a half.
Biggest drawback I noticed was my donwload speed.
I am on a 300/30 plan and without YAMon I actually get those speeds (even a little more). With Yamon my upload was still 30, mut download maxed out at 260
So back to the "native" RMerlin monitoring for me.
Welcome To SNBForums
