Update unsuccessful for AX3000 router
unlevels
Hi, Trying to install asuswrt-merlin but I get the update unsuccessful error. Checked everything and it looks right. It's an AX3000 router.
Current version: 3.0.0.4.386_48377
I used the RT-AX58U since the website says its the same firmware. Tried the 386.5_0, 386.4_0, 386.5_2 and none worked. Maybe I'm missing something?
Is it a V2 ?
RT-AX58U_386.5_2.zip – OneDrive (live.com)
And upload firmware through LAN cable.
Maybe you can try to do a factory reset first before trying to upload this one.
Make sure you unzip the downloaded file too before uploading it.
RT-AX58U_386.5_2_cferom_puresqubi.w should be the name of the file that you upload.
Is it a V2 ?
I have a V2 RT-AX3000, and unable to install.
So bad, is it not supported? just bought it from Amazon!!
Is there any chance it will ever be? Or should I return mine and get something that is supported?
Yes, and replace it with this one:
  • RT-AX68U or
  • RT-AC68U V4
If you want to spend a $100 more go for this one instead.
  • RT-AX86U or
  • RT-AC86U-PRO
Do not invest money in AC class, you want an AX class router. The Pro versions are newer.
RT-AC68U_V4 is officially no longer supported by Asus.
