Update VPN client policy at runtime
Paul_1984
I want to configure my router for various OpenVPN client profiles (US, EU, Asia, ...), but I want any network device to be able to select/change which profile to use ad-hoc without logging into the router each time.
I started down the path of creating SSID specific IP ranges and then assigning each range to the various VPN policies, but I don't think that's a very elegant solution. I'm a noob at router programming, and I have little shell scripting experience, but I think I have a pretty dynamic solution... if the performance is acceptable.
Here are my requirements and assumptions:
  1. Router: Asus RT-AC5300 with Merlin RT-AC5300_380.65_2
  2. Only use OpenVPN (this is a requirement for AirVPN)
    • AirVPN only allows 3 concurrent connections, but I'll deal with that later
  3. Any device can select a different VPN client without logging into the router
  4. The whole process should aim to limit overhead
    • This script probably requires every network packet/destination to be examined, but that is ok for this proof of concept... unless it truly kills network performance.
  5. A long-term solution should probably be a custom web form hosted on the router that does not require a login.
Here is my [potential] solution:
  1. Configure the router for several VPN profiles (client1, client2, ...).
    • Policy rules must be enabled and enforced.
  2. When the router detects a device attempting to browse to a specific IP/URL, then execute a custom script.
  3. dynamic_vpn.sh
    • Iterate through each client and remove any policy rules for that device.
    • Add policy entry for the device under the chosen client (based on IP/URL)
Here is my draft script:
#!/bin/sh
## File Name:      dynamic_vpn.sh
## Author:         Paul_1984
## Created Date:   03/30/2017
## Update Date:    03/30/2017
## Purpose:        Update VPN client policy at runtime.
## Notes:          (1) This is based on the capabilities of Asus RT-AC5300 with Merlin RT-AC5300_380.65_2
##                 (2) Assumption: only using OpenVPN
##                 (3) Assumption: each VPN client may have a default CIDR range (192.168.1.144/28).
##                 (4) Assumption: every SOURCE is on LAN (low-risk).
##                 (5) Assumption: any SOURCE is allowed to update their VPN (even guests).
## Instructions:   (1) File location: /jffs/scripts/dynamic_vpn.sh
##                 (2) Edit /jffs/scripts/???.sh; append the following commands at line ???:
##                       DESTINATION_IP="$TBD"
##                       VPN_COMMANDS_LIST="192.168.250.1 192.168.250.2 192.168.250.3 ..."
##                       if [ `expr index "$VPN_COMMANDS_LIST" "$DESTINATION_IP"` -gt 0 ]; then
##                           SOURCE_IP="$TBD"
##                           /jffs/scripts/dynamic_vpn.sh "$SOURCE_IP" "$DESTINATION_IP"
##                       fi
##                 (3) Have PC/iPhone/tablet browse to specific IP to update VPN policy; 404 is expected.
## Change History: (03/30/2017 by Paul_1984) Added option for no VPN.
## Known Issues:   (1) Is this even possible?
##                 (2) Where to place this file?
##                 (3) What other scripts require update?
##                 (4) What parameters will it receive?
##                 (5) Confirm VPN Client names (tun11, tun22, ...).
##                 (6) Replace all "ToDo" placeholders.
main() {
    SOURCE_IP=$1
    DESTINATION_IP=$2
    case "$DESTINATION_IP" in
        "192.168.250.1") set_client_policy "tun11" ;; # Client1 = US
        "192.168.250.2") set_client_policy "tun22" ;; # Client2 = EU
        "192.168.250.3") set_client_policy "tun33" ;; # Client3 = Asia
        "192.168.250.4") set_client_policy "tun44" ;; # Client4 = TBD
        "192.168.250.5") set_client_policy "tun55" ;; # Client5 = TBD
        "192.168.250.6") set_client_policy "tun66" ;; # Client6 = TBD
        "192.168.250.9") set_client_policy "wan" ;; # Don't use any VPN
        *) ;; # Do Nothing
    esac
    return 0
set_client_policy() {
    NEW_CLIENT=$1
    VPN_CLIENTS="tun11 tun22 tun33 tun44 tun55 tun66"
    logger "dynamic_vpn.sh [Begin]: SOURCE_IP=["$SOURCE_IP"] NEW_CLIENT=["$NEW_CLIENT"];"
    for CL_X in $VPN_CLIENTS # Loop each VPN Client
    do
        # Step 1: remove all specific SOURCE_IP policies
        CL_X_POLICIES="ToDo: Get all policy records"
        for POLICY in $CL_X_POLICIES # Loop each policy record
        do
            POLICY_SOURCE_IP="ToDo: Get the source IP for a specific policy record"
            POLICY_DESTINATION_IP="ToDo: Get the destination IP for a specific policy record"
            POLICY_TYPE="ToDo: Get the type for a specific policy record (VPN/WAN)"
            if [ "$POLICY_SOURCE_IP" = "$SOURCE_IP" ]; then
                #ToDo: delete policy record
                logger "dynamic_vpn.sh: SOURCE_IP=["$SOURCE_IP"] removed from VPN_CLIENT=["$CL_X"] DESTINATION_IP=["$POLICY_DESTINATION_IP"] TYPE=["$POLICY_TYPE"];"
            fi
        done
        # Step 2: Create new policy for SOURCE_IP; assume each Client has default a CIDR range
        if [ "$NEW_CLIENT" = "$CL_X" ]; then
            #ToDo: create policy record for $CL_X $SOURCE_IP destination="0.0.0.0" type="VPN"
            logger "dynamic_vpn.sh: SOURCE_IP=["$SOURCE_IP"] added to VPN_CLIENT=["$CL_X"];"
        elif [ "$NEW_CLIENT" = "wan" ]; then
            #ToDo: create policy record for $CL_X $SOURCE_IP destination="0.0.0.0" type="WAN"
            logger "dynamic_vpn.sh: SOURCE_IP=["$SOURCE_IP"] excluded from VPN_CLIENT=["$CL_X"];"
        fi
    done
    logger "dynamic_vpn.sh [End];"
    return 0
main "$@"
exit 0
Why not simply configure a static IP on the client, and change the IP based on which tunnel you want to use? You can then define policy rules based on those different subnets.
I considered that by way of various SSIDs, and then just changing my network as necessary, but I didn't like that because:
  1. It would flood my already congested neighborhood with many more SSIDs; they could be hidden, but they would still be there.
  2. It wouldn't work for my desktop; I could manually set the IP, but then my other computers that stream from my desktop would fail.
  3. It just seems like a clunky solution.
Is there a script that only executes because of a failed DNS lookup? Maybe this script can be injected there instead of every network request. That should not have much of an impact on performance like that.
