Newby here. When I set up my new Merlin based Routers and added Mesh nodes, the instructions were to make sure the nodes were using the latest firmware, reboot to factory settings, do NOT log into the node but instead let the main Router find and add them as Mesh nodes.
Now I am getting a "firmware update" notice inside of the main Router and it is one of my Mesh nodes.
When I then attempt to update that node, the next screen is asking me to log into that particular node, but that seems to be against the original instructions.
Question: Do I log into the Mesh Node and perform the firmware upgrade? Or, do I remove the node and manually update the firmware, reset to factory settings and re-add the node through the main routers Mesh utility (like the original instructions?)
