Thanks for the reply. I tried a power cycle and also a hard reset. Still the same resultPower cycle off for a couple of minutes. Remove any USB devices and try again.
All that for a browser? Wow! I have Chome, Edge, Firefox and still have Internet Explorer, all current updates, what's the preference? I was using Chrome.Try a different browser.
Chrome is fine, I do all my testing and development in Chrome, but often the issue comes from an installed addon. Trying a different browser is the fastest way to work around it.All that for a browser? Wow! I have Chome, Edge, Firefox and still have Internet Explorer, all current updates, what's the preference? I was using Chrome.
Thanks!!
After I restored it to 386.4 via the restoration tool I attempted to flash the stock firmware to see if the issue was sorted but it did the same as when I attempted previously. Something is not right as i cannot update via GUISame problem on my AC66U B1(from 386.2_6 to 386.4), there came a notice while uploading 386.4 firmware, but after I did these:
1) Factory Reset
('Ping 192.168.50.1 -t' was not working after factory reset, I never met this before)
2) Power off
3) Power on
4) Upload 386.4 firmware
I don't know why, but it works
I was using chrome which is the browser i have always used. I've been using your firmware for many years now and have never had any issues. The only thing that has changed is me switching from the RT-AC5300 to the GT-AX11000 just a few days ago. As soon as i got the GT-AX11000 I installed Merlin on it and configured it to my liking. Never noticed an issue until the update was released. Is it possible my browser's history could be causing the issue?Try a different browser.
You have the exact same issue as me. I could only flash the firmware using the restoration tool and even after flashing to the latest I still had the same issue. I attempted an install of the stock firmware just to test if it worked via the GUI and got the same result as before.Same problem here with AX86U. Nothing worked. Factory reset. Could not flash back nor could I go to the Asus official firmware. I used both Chrome, Edge and Opera. Cleared cache etc. The only thing that worked for me was upgrading through the browser on my android phone.
Can you tell more? How can an addon interfere?often the issue comes from an installed addon
Ad blocker preventing access to a router resource. Addon that modifies the page's DOM format. Who knows what everyone's addon may be doing to mess with the router's webui.Can you tell more? How can an addon interfere?
I still haven't resolved the issue. I set both my devices up and don't have time to retry. I just got the AX68U to use as a mesh node and attempted to flash the firmware. The same issue is present on that device as well.I've run in to the same issue with my RT-AX68U. I do have a USB drive attached so I unmounted it but had the same issue. I've tried Firefox, Chrome and Edge with the same 'unsuccessful' result.
Welcome To SNBForums
